I've heard of it on here, but haven't verified in my manual. I always use it anyway since I don't like the idea of relying on just my parking gear.vliou wrote:Seriously?!?! Who has heard of this before?
I didn't end up going outside in the buff. . it was real cold this morning. With that said, I still haven't had a chance to verify mine. .vliou wrote:Hmm, I did check the manual, and it doesn't mention anything about this =|
Mine: '02 Pathfinder with 174,000 Kms on it. Still running original rear brakes (had them checked last year and they were still over 50%).I'm on my second set of front pads with original rotors...never even been turned.No problems whatsoever. I don't drive it easy either, so I can't figure out why yours is so hard on brakes.(My '03 Sentra is worse than my Pathfinder by the way. I'm doing my third front brake job next week, and it only has 90K Kms. on it.)vliou wrote:Wow, I just found out i'm only getting 14,000km's between front brake pad changes!!!
I also just found out i'm supposed to be getting 30,000 MILES!!!
3 dealers, 3 different times...what's going on here?
I've heard this before. I went through brakes pretty quick. Not 5 months, but maybe a year or 12k miles. Remember that aftermarket pads may not las as long as OEM too.SnowSurfLax wrote:Check your manual. I know the owner's manual says to always apply your parking brake to keep the rear brakes in adjustment. That's how Nissan likes to do it.
I smoked a set of brakes in 5 months time by not doing that.
You should be getting a HELL of a lot better than that. My '01 has about 175Kmiles, 1/3 of which is towing my (brakeless) 2000+ pound boat trailer (withseveral hundred pounds of SCUBA gear in the truck.). I've had to change the front pads twice, the rears, never. I'm getting due to change the frontsagiain, I suspect, but no warning telltale yet.vliou wrote:Wow, I just found out i'm only getting 14,000km's between front brake pad changes!!!
