navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Mon Sep 06, 2004 1:28 pm
you can also get a cube at NAPA or autozone that has a bunch of different designs and hooks onto the end of a ratchet, much easier and you can apply presssure while turning too
also, when you use the c clamp, put an old brake pad in there to push the piston in, and also, only do it on one at a time, it can push the other piston back out if its not back on the rotor, that would be bad, so push it in, new pads, put it back, bolt it down, then next one
