mryzza »
https://forums.nicoclub.com/mryzza-u42246.html
Thu Sep 21, 2006 3:24 pm
Yes, the shims. So I have to go buy those now at any local auto parts store? I ended up putting the pads without the shims. I greased the pads and the bolts. But, now I have two more problems. I can't remove the rear disk because it is stuck... I had to buy an axle nut for it but it's still impossible to move so I will try again tommorow.
Also, on the front right side the wheel seems to be off. It won't fit correctly on the rotor.... I think the caliper is slightly off and is blocking the wheel from sitting correctly on the rotor so I'm gonna have to remove it again tommorow and try again. Meh, I'm tired....
