NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Fri Jun 04, 2004 4:10 pm
lol...Your fluid came out of your brake master resivor...the fluid that is in your caliper has to go some where when you push the caliper back in right? what it does is it goes back in to the master and over flows through the top. This is normal but a note to make here when ever you compress calipers with out opening the bleeder make sure your master cyl cap is unscrewed so it wont put to much pressure on the other seals in the system. it will allow the fluid to more freely return to the master.
I laughed at first cause it took me a second to figure out what you were saying cause I am so used to that fluid coming out like that being I could do 5 or 6 brake jobs a day sometimes.
