jhilb wrote:Thanks.
I don't have to open the bleeder to push the pistons back do I? I can just use an old pad and a clamp to push them back, after taking the cap off the master cylinder reservoir?
I tend to open the bleed screw as pushing it back into the reservior could cause it to overflow if you ever topped off the reservior as the level dropped from pad wear and it tends to push contaminants back up. I generally flush the system while I am changing the pads so I prefer to not to put more junk to be flushed into the reservior.
jhilb wrote:What am I looking at here please? Am I getting into something I am not going to be able to handle?
I was expecting to be looking at the rotor.
Jeff
Hard to tell as I haven't worked on a Frontier's brakes (despite the fact my parents have one). And the picture you provided is a bit small. A quick look at the FSM indicates you'll have to the hub as the rotor is attached (I hate this type of set-up).
http://www.nicoclub.com/FSM/frontier/2004/fax.pdf
