Since he's using ATE he could probably use a bottle of some cheap stuff to flush out the nasty old crap that's in there and once that's done start using the more expensive ATE. Then just bleed it again until it comes out blue. You also might want to pick up some Speed Bleeders...cheap and useful.Dori Dori wrote:It took a lot of fluid for my brakes to be COMPLETELY flushed...I think I wasted 2.5 bottles of Motul.
Maybe I'm just wearing my stupid hat today, but are saying that what I advised (and what I plan to do myself) *would* be OK? As I said above, I'd run the cheap stuff through to flush out any crap that had taken up residence in the lines and then drain that stuff out and run the Super Blue through until I...well, see nothing but blue.Exar-Kun wrote:DONT mix ATE super blue and another brake fluid type. its different in its formualtion(duh), while "compatible" it is by no means a good idea to mix it. flush the system out until all you have is ATE....
OK, I trust both DD and yourself, so I guess I'll order another liter of Super Blue from SPL.Exar-Kun wrote:that seems like a waste of the cheap brake fluid...but yeah, as long as you flush it through with the ATE you plan on using, yoiu'll be fine.
My original thought was to flush with the cheap stuff, drain the system, replace the lines with my stainless ones and then put in some ATE and flush as needed.
Since that's not a good idea, I guess I'll need more ATE.
Do you think 2 liters will be enough?
