Brake noise!
Sliding_S14
Car: Sliding from the Side
for some reason not sure if its normal but when im going at slow speeds coming to a stop i can hear a click, i can tap the brake and hear it while im rolling in nuetral. somtimes its louder then other times. am i paranoid? or anyone have somthing simular, and its not a sqweek its a loud click like metal taping against metal or friction between metal.
NISTECH
check your axel nut torque. also look at your brake pad fit in the carrier. see if there is alot of slop in the holder.
