paranoidjack »
https://forums.nicoclub.com/paranoidjack-u33168.html
Sat Oct 10, 2015 9:35 pm
I've got a few thousand on my first set. They don't "grind," but they do make a whooshing sound during spirited braking until below 20mph or so, then they are very quiet.
They are cross drilled and this is not common with cross drilled rotors, perhaps that explains some of the discrepancy you guys are talking about.
Given the chance again, I'd prefer to lose the noise and have the extra braking surface of a smooth set of rotors. Cross drilling and venting are really only for those that brake hard and frequently and need to keep them cool; in my opinion it's better to have higher quality brakes than those that cool quickly. If you need to quickly cool the brakes on your m45 on regular roads, you should probably check your driving!
