IvoryJ30t »
https://forums.nicoclub.com/ivoryj30t-u9485.html
Fri Feb 06, 2004 12:19 pm
bleed the brakes, and if you still cannot maintain a normal pedal feel, there may be leaks or a bad M/C.
with your symptoms, i would say the M/C is the prime suspect. but bleed the brakes before you jump to conclusions. after you get any air out of the lines, its easier to make a proper diagnosis.
