brake master
IanS13
hello my turbo sits close to my brake master cylinder how can i protectet it from the heat of the turbo can i wrap it in some heat wrap. any one got some pic's of a custom heat sheild so i can get an idea.
C-Kwik
what kind of turbo are you running? There are some premade turbine heat shields out there for certain turbos.
IanS13
t3
gabossie
Car: Your mom
Turbo blanket works too. They aren't particularly cheap though.
http://www.horsepowerinabox.co...1.htm
574-240sx
Car: Nissans, Toyotas, Subaru
i used a piece of sheet metal bent it and cut it down to fit. I wored it in place with some bailing wire. It doesn't look the best but it helps not melt my brake lines of master cylinder resevior. Nick
IanS13
tru am going to get some heat tape from summit and wrap them is this a good idea, or should i just wrap the turbo.
daniel240
Car: cars/motocross
i also just made a heat sheild out of sheet metal for the bmc and for the turbine housing on the turbo. heres a pic
