Brake lines, what do they do? Why upgrade?
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
What does stillen's Gstop Stainless Steel Brakeline Kits do.
Why is that such an important upgrade?
Also why is there only a rear set of breaks. Sport Rotors - 1-Piece.
Thank you
beeristasty
Car: 07 Altima 3.5 SE
dldjros69 wrote:What does stillen's Gstop Stainless Steel Brakeline Kits do.
Thank you
They're actually made by Goodridge, and they replace your oem/'standard' brake lines.
They offer better braking b/c ss braided lines expand less than regular hoses under the same amount of pressure.
idk, maybe one of the Stillen guys can answer that.
yw
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
They are more rigid and allow for higher pressure to move through the lines. Thus eliminating the "spongy" feeling, (fade), in the brake pedal, and they are weather/corrosion resistant. So they have a longer use life than stock rubber lines
dldjros69
Car: 2012 Evo Gsr
Adidas are you thinking about this upgrade?
Has anybody done this?
Would it be worth it to get this for a daily driver?
08Coupe
Car: 2008 Altima Coupe
For a daily driver I feel the Altima brakes are pretty good, but from past cars in order of improvement from stock
1 Better pads and fluid2 Rotors3 Big brake Kit4 Lines
adidas2go
dldjros69 wrote:Adidas are you thinking about this upgrade?
Not worth is for a daily driver with stock brakes. If you get the Big Brake kit, then get these
