Brake Line
John16
Car: 1993 Nissan 240SX hatchback
IS this a brake line? While I'm working on my brake system and go underneath the car to clean all that grease I see this line disconnected. Is this is a brake line? Where does it go? Any advise will appreciated.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
That's a clutch damper. Easy to delete, and evidently someone did.
John16
How is that posible waooo! Anyway The line comes out of that square box which is the clutch damper right? And where that line goes attached to. Let me keep on seaching. Any advise to replace back to stock i'll apreciated.
VStar650CL
Technical Expert
When you delete the damper it can simply be disconnected from the clutch hydraulics. Someone deleted it on your ride but didn't bother removing the hardware. Deletion gets you a stiffer pedal with better feel, many SX guys do it.
John16
Got it! Will take it off one of these days. Thanks!
John16
Does anyone knows if theres a kit to repair the brake lines that goes into the master cylinder, Just at the end of the line that attaches to the MC
