brake line retaining clip removal.
mr.zenki
how do i remove the retaining clip attached to the front brake line that holds the brake line on the strut bracket? i mean which way do i push it? the thing is hard as hell. i could use force but im afraid im gonna brake it and wont have a replacement. the car is an s14. thank you
C-Kwik
It essentially just slides out away from the line. One side should have a small tab that sticks out. I usually just tap it out using a hammer on the back of a screwdriver. It's not terribly hard to remove.
nismofly
Car: 89 Nissan 240SX Hatch
i did the same thing, hammer with screwdriver
i then used a hammer to get them back on the coilovers
mr.zenki
aight thanks guys. i was afraid to use force.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
mr.zenki wrote:how do i remove the retaining clip attached to the front brake line that holds the brake line on the strut bracket? i mean which way do i push it? the thing is hard as hell. i could use force but im afraid im gonna brake it and wont have a replacement. the car is an s14. thank you
I snatched mine off with the needle nose.
mr.zenki
****, i just noticed that i spelled break wrong ( i meant break instead of brake). english is so complicated. oh ****, it rhymes.
