Brake line info
craig1980
Car: 2003 Nissan PF 3.5
Hi all,
I need to change the rear brake line that connects to the LSV. The one that is right above the bypass cut valve. Anyway, I would like to make one trip to the auto parts store and was wondering if anyone knows what type of flare is used and what thread and pitch for the brake line fittings I will need. Thanks in advanced!
atraudes
Car: 2001.5 Infiniti QX4 4WD
Better late than never, right? :gapteeth: You'll need a 10mm flare nut wrench for the 3 brake lines it's attached to, and a 12mm wrench/socket for the bolt fixing it to the axle. I bought this guy. The only other tools you'll need are flat-nosed pliers of some sort to pull the clip off the top and all the brake bleeding gear.
