Post by aaronscomp » https://forums.nicoclub.com/aaronscomp-u88194.html Mon May 18, 2009 7:26 am
Post by klattr1 » https://forums.nicoclub.com/klattr1-u1743.html Fri May 22, 2009 3:55 am
It's the non-ABS/5-speed brake booster that you want...It's around 1" shorter. Also, sounds like you are talking about master cylinder clearance as well. A D21 Nissan truck master cylinder has the brake line ports on the opposite side and gives better clearance (get's tight around strut tower area though)aaronscomp wrote:Ok i have a 91 kat the center line in the break booster keeps breaking then all the fluid leaks out and no breaks i have a automatic break booster is a manual one really that much smaller. The line is pretty much touch the manifoild so i think when i drive the engine just moves causing the manifoild to hit the line crakcing it.
Post by aaronscomp » https://forums.nicoclub.com/aaronscomp-u88194.html Sat May 23, 2009 2:23 pm
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
