Brake lights wont turn on
DowtheFilipino
Car: 1994 Nissan 300zx
My brake lights wont turn on when I press the brake. I changed my bulbs and my fuses are still good. Any ideas? I have a 1994 300zx. Any help would be greatly appreciated.
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
There's a brake switch which gets pushed every time the brake pedal hits it. Yours is probably bad, or the connection is loose.
t.mcginley.jr
1966 Ford Mustang
It should be either attached to the brake pedal assembly or somewhere near it, I haven't actually looked at mine.
Delrioz32
Car: 1990 Nissan 300zx n/a auto
Not sure if you fixed it yet but for others with the same problem
There's a relay/ tail light sensor behind the driver side tail light
Remove the cover and it should be towards the left. It's a green box looking thing.
