420sxse »
https://forums.nicoclub.com/420sxse-u27656.html
Fri Apr 29, 2005 11:41 am
It's real easy to find, the buttons are back underneath the dash, so when the pedal is depressed the stopper moves away from the button. The brake lights go off when the button is pushed in. If the rubber is gone, the button sticks through the hole that the stopper was pressed into, so it stays in the "out"/lights on position. Stick something up there on the pedal arm to keep that button in until you get the part.
