Buccaneer_9 »
https://forums.nicoclub.com/buccaneer-9-u69793.html
Fri May 14, 2010 6:02 pm
This just happened this morning and I haven't driven the car yet. If it isn't the brake light switch, is there any other issue that comes to mind?
Thanks for the info.
Edit: Got home, re-connected the battery and pulled the fuses for the tail-lights. The brake lights went out, but now they won't turn ON. I tried to squeeze my fat head under the dash to find the stop lamp switch, but I could not locate it. I did however hear a relay of some sort click each time i depressed the brake pedal. It sounds like it is somewhere near the center console.
Got discouraged, disconnected the battery and will try again in the morning.
