jimbyjimb »
https://forums.nicoclub.com/jimbyjimb-u93878.html
Sat Jun 28, 2008 11:42 am
Check the Master cylinder and ABS unit under the hood for leaks first, if no leaks then pull the wheels and give the flex hoses, slave cylinder boots, bleeder screws and connections a good look. Any fluid leaks should be obvious.
