Brake lights
DiegoLivin
Car: 2002 PATHFINDER
2002 PathfinderBrake lights will not come on when I hit the pedal, However top light still works. I went thru all the fuses, under the hood as well , bulbs are perfect. I looked at connections on the brake pedal seem to be functioning properly.What else could this be? I cant find a "box" referred to in another post.
Thanks in advance
DiegoLivin
/bump!
Help!!! Stumped
billarky
Most likely candidate is the brake light switch. Just purchased a replacement switch, but can't figure out how to get the old one out. Very little room to get hands up in there and not sure if the switch must be unscrewed or if there's another trick to getting the old one out.
Ramius83
Car: 1995 240sx SE
If your center brake light is working, then your Brake light switch on the brake pedal is functioning correctly. You need to check for power at the rear taillights. Hook up a Test Light in place of the rear taillight bulb and see if it lights up when you press the brake. Make sure you try both wires going to the brake light bulb as one is ground and the other is the power wire.
james_lewis
so what is the solution to this ... I have the exact same issue on my '99 QX4
TIA
Meaux
Car: 94Q45, 92Porsche 968, 72Porsche 911, 89Maxima SE, 98Honda Civic, 85F150 w/95 5.0
This may or may not be ant of ya'lls problem, but I just found out that the reason my Brake Lights won't go "off" is because of a Plastic Plug on the Brake pedal shaft... The plug fell out in pieces and the switch just goes thru the Hole on tha bracket...
89 Nissan Maxima...
