onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Jan 26, 2006 8:54 am
skipping post....
HAHAHA, j/k.
Do you parking lights turn on at all?
Basically, here is one way to figure it out - you will need to use a multimeter and probe around the taillight housing connector to figure out which wire is causing the problem.
Have someone in the driver's seat.
Probe the connector - I believe it is 6 wires or so? - connected to the taillamp, you can disconnect the harness.
Find out which ones are ground.
Next, have the person turn on the parking lights. See which ones go positive.
Next have the person press the brakes - see if the last wires go positive
- if they do, then there is something wrong w/ the housing itself - commonly, the ground wire in teh housing fuses w/ the plastic and makes a "dirty" ground, which messes up your brake lights. Quick and easy way to fix this is to unscrew the ground, clean the terminal & plastic area, and screw back on.
- if they don't, then there is something wrong in your circuit, which you will have to consult an FSM and be prepared to have lots of fun tracing the wire!
Let me know if that helps.
