Ahhh fine its either the switch is bad on the pedal like stated or the grommet that depresses the switch in when the pedal is at rest has deteriorated and fallen out.
Ill go for the grommet as it is a very common issue, as it hardens and cracks. Youll see a hole and the stop lamp switch going into a hole, if the grommet has busted, vs the switch resting on the grommet of course, if it is good.
Only reason I am typing this as my last post on this was deleted... I forgot about that. The ****er that started the post deleted it after I ragged on him then gave him the answer anyway... Selfish prick asks for info, gets his feelings alittle hurt but gets his info, then deletes it so no one else can get such info.
edit: you know Im just razzing you.... right??? Oh and by typing "brake and lights and on" for the 240 section I found many threads on this
