Brake lights stay on, draining battery
krazy88
Car: 1989 240sx
My brake lights stay on even if the key is out, and no one is pressing on the break. I assume its the sensor, but i could be wrong. If this is the case could someone get a picture or descibe it in more detail than "its by the break pedal". Thanks for the time
krazy88
Car: 1989 240sx
any write ups?
omgdudewtf
Car: 1993 240sx SE
Sounds like your brake pedal position sensor. Normally it will be near the top of the brake pedal assembly. It "should" have a lock nut and thread into the brake pedal bracket. See if you can locate it, disconnect it and see if your brake lights go off. Or see if it is visibly sticking and replace it.
Good luck.
JeromeS13
Car: 2008 Subaru Impreza STI
This is a very common problem. There is a small bumper-pad that is in the brake pedal assembly that actuates the switch. Over time, they become brittle and break. You can pick up new ones from the dealer for a couple of bucks. Do some searching around and you'll find numerous threads about this.
-Jerome
shrapnail
Car: 03 SE-R, 89 240sx
ye
JeromeS13 wrote:This is a very common problem. There is a small bumper-pad that is in the brake pedal assembly that actuates the switch. Over time, they become brittle and break. You can pick up new ones from the dealer for a couple of bucks. Do some searching around and you'll find numerous threads about this.
-Jerome
yeah, that kicked my butt a bit on mine too; I pulled the bulbs till I got it figured out
You might as well replace the one near your clutch while your at it
