Brake Lights problem *PIC*
Greg21
Car: '91 240sx
Problem: Brake lights won't turn on
I have checked 2 things, fuse + bulbs. Both are still good, so I am thinking it is the switch underneath. Does anything look wrong from the pic? Which one is the brake switch and what is the other one?
The big problem is that when i checked the pedal...the little white probes dont hit anything. There are holes in the brake pedal where they look like they should touch. I dont understand how the switch is supposed to work if neither of them touch.
Is there anything else that could be causing my brake lights to fail? I could only think of these three things unless theres something wrong with wiring(i hope not).
Hope this helps:
Picture: http://www.tamparacing.com/pho...age/1
SplitSecondConcepts240
Car: 93 240sx
it seems like u dont have a rubber stopper
Car: 93 240sx
is ur car standard?
Greg21
Car: '91 240sx
but if i were missing a rubber stopper, then wouldnt my brake lights always be on? because the lights come on when the pedal is pushed and the probe moves out...
Greg21
Car: '91 240sx
its an SE
Car: 93 240sx
duno but didnt u stay there not touching anything
Car: 93 240sx
well i have the repair manual doesnt really say anything it just has pics and it has in the brake pedal - the top one is the stop lamp switch and bottom one is the ''ascd'' cancel switch ''automatic speed control device'' and on the clutch pedal there is the clutch interlock switch on top and a ascd cancel switch or a pedal stopper in the bottom so im guessing it might be one of those switches sorry i cant help u im just putting what it says in the book and its very confusing i only have a stop lamp switch but my car is an automatic
Greg21
Car: '91 240sx
ya its the fact that their a hole where i guess it should touch the probe...i cant figure this one out..i guess its just gonna go to the nissan dealer
95lstegman
Car: 1989 570SX, 2005 Acura RSX, 1994 Toyota Corolla
this is probably what you need: click here for the info i just duct-taped a quarter over mine and adjusted the sensor so the quarter doesn't slam into it, but merely depressed the plunger just so and doesn't damage the sensor itself.
