Brake lights not working
insne
Car: '15 Rogue SV AWD
I was upgrading my led bulbs on my brake lights and they end up not working. I tested the first fresh bulb I installed, worked great. While testing the second bulb they both didn't light up. Tried to put the old one back and no good. The third/middle brake works. Did I blow a fuse? How do I fix this? Thanks
phjake
Car: 2015 Nissan Murano SL
A blown fuse sure sounds like a possibility. Your owner's manual shows you the location of the fuses, and correct bulb numbers to use when replacing them, in section 8 "Maintenance and do it yourself".
insne
Thanks, fixed it... for now. Went through two fuses to find out that the one of the new bulbs had bad ground. Waiting for replacement bulbs, hope that's the case.
Return to “Rogue Forum”
