Brake Lights Always on!!!!
KrazyS0b
Car: 89 s13 redtop, f*** Fidanza, Spec stage 2 clutch, Greddy FMIC, HKS SMF Reloaded, HKS SSQV
As the title says my lights are always on. I did an SR20 redtop swap. I have an 89 240. what i have done so far and noticed so far. Well i figured its getting power from somewhere its not suppose to. So i disconnected the brake switch connector and the lights shut off so i figured maybe its getting power from somewhere between the fuse on the driver side and the switch. So i pulled the fuse. the lights went out. So i guess its getting power somewhere between the fuse box and the battery. Is this thinking right? or does it come from something else. or am i totally lookin in the wrong place. I noticed that my right turn signal works normal speed and both front and rear work. But the left side the front one blink 10x faster than norm and not getting any thing at all from the rear one. Could these be linked? Thank u for any help
danielsan
Car: 1991 240sx coupe SE
if you disconnected the brake switch and it went out that that means the switch is stuck or broken.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Another option to consider yes zerothread?id=140463
squbafreak15
Car: 89 240sx rb20det
i had the same problem its just a little screw thing on the switch if that doesnt fix it then there is alittle crappy rubber or plastic i forgot which peice that cracks and you need a new switch
KrazyS0b
k kewl thanks everyone i will check it out
