DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Wed Jan 08, 2003 9:15 am
Related story:
This week I replaced the brake pads on a friend's motorcycle. 13,000 miles and this was his first pad replacement. Keep in mind he's a mechanical engineer. With NO embellishment, here is how the conversation went before I did the work:HIM: I think my brake pads are worn. At one point, my rear brake began to make a grinding noise, so I quit using it and I've been using my front brakes only since then. Now, my front brakes are starting to grind too.ME: When did your rear brake begin grinding?HIM: Oh, maybe about a year ago.ME: WHAT?!! <feeling faint, I reach for a chair to sit on>
So I replaced his pads for him. Get this: His front pads were both worn down to within .010" of the pad's backplate. The rear pads were worse! The rotor had cut a groove maybe .1" into the backplate. The pistons were so close to popping out of the caliper that I had a hard time getting them centered enough to press back in.
