Brake Light warning stays on
A home for 1983–1989 300ZX owners!
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
I have the brake light on the center cluster staying on after I disengage the emergency brake. They light stays on but once the car is warmed up and I re-start it again the light goes out. The brake fluid is full, any ideas?
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Don't know about the Z32, but does it have a low brake fluid sensor? I wouldn't think it would if the Z32 doesn't, but I'm not sure. I don't think it came with ABS either except overseas, so I doubt it would be that. I'd bet your switch is just stuck. Go at it with a meter and see what you come up with. Should just be a simple open/closed switch.
BadQ45t
This is a Z31 and the fluid is full, first thing I checkec.
Ace2cool
I mean your E brake switch.
BadQ45t
Where is that?
Ace2cool
Usually attached to the e-brake lever on just about any car I've ever worked on...
BadQ45t
So update on this odd issue, when I drove the car for 20 miles the light goes out. It comes back on after sitting for more than 20-30 minutes and then goes out again.
I am thinking there is something going on with the brakes but oddly they feel great and the brake fluid res is full
Ace2cool
Did you check the switch?
BadQ45t
The e brake switch? I don't know where that is, but woudln't think that part would either work or not work. After the car runs for 20 minutes the light goes out.
Can you point me to the switch? Meanwhile, on Monday I am taking the car to my mechanic and having the brake fluid drained out of it and refilled since I haven't done that in a long time and see if that helps the situation.
Thanks!
Ace2cool
It should just be on the parking brake lever, under the boot. May have to remove the console to get to it.
BadQ45t
Issue fixed, while the brake fluid level was not low a fluid change and cleaning of the system fixed it, magic!
Return to “300ZX (Z31) Forum”
