Brake light warning light comes on. no burned out bulbs on c
windjammer007
Car: 1992 300ZX coupe.
Brake light warning light on dash comes on when engine is running and headlights are on. Comes on when brakes are applied and headlights are off. Also when lights are off, the parking lights and instrament panel lights come on when brakes are applied. All bulds were checked and are working. I also just changed all tail lights to LED. They work fine.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
There are bulbs out somewhere. The JDM bulbs also have a different resistance for some god-forsaken reason, so if you have JDM tails, that's where I'd look.
It has to be one of the four main bulbs in the tail light though, since it's on when the headlights are on.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
windjammer007 wrote:Brake light warning light on dash comes on when engine is running and headlights are on. Comes on when brakes are applied and headlights are off. Also when lights are off, the parking lights and instrament panel lights come on when brakes are applied. All bulds were checked and are working. I also just changed all tail lights to LED. They work fine.
Your new LED bulbs do not have the same resistance of the OEM bulbs. There is a tail lamp relay/module that monitors
the complete circuit resistance, located in the hatch tail lamp area. If the resistance falls outside the specs (ie, a bulb burnt out or new lamps having a different resistance then OEM), this will activate the indicator on the dash. Some people just snip the wire that runs to the dash indicator to the relay/module or get the proper bulbs.
Ace2cool
Oh, duh. Whoops. I need to check my reading comprehension. That's twice this week.
