Brake Light, VDC Off, Slip indicators will not go off....05 QX56.
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
boosoo
Car: 2005 Infiniti QX56
05 QX56.....My brake light indicator, slip light and vdc off light are on and will not go off. Any ideas what this could be?
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
boosoo wrote:05 QX56.....My brake light indicator, slip light and vdc off light are on and will not go off. Any ideas what this could be?
First off, welcome to NICOclub! Glad to have you as a new member of this forum!
Sorry to hear about you issues! The very first thing I would check is the fuses, it kind of sound like this might be a good possibility. Check the fuse box in the cabin first, if all looks well there, check the fuses under the hood. If you are standing in front of your QX56 looking at the engine, the fuse boxes are located on the left side in the far back, close to the cabin and windshield. The covers on the fuse box will show you which fuses are for what, I think those three items may all be the same fuse, hopefully that is all this is. HOPE THIS HELPS!!!
psmwrx
1st check brake fluid level ......should check for codes in abs it could be either c1142 pres sensor circuit or c1179 delta s sensor
Return to “Armada Forum / QX56 Forum / QX80 Forum”
