CWH S13 Silvia »
https://forums.nicoclub.com/cwh-s13-silvia-u78613.html
Thu Oct 18, 2007 6:19 pm
You're brake light switch under the dash has two nuts on it you lossing one up and then the other, then there is a connector that needs to come off, after that replace it wit the new one and set the lentgth to where you want it cause the nuts set the switch at the possition to where you want the brake pedal to be when the lights go off, k, but you can also have different problems so if they still dont work after you replace the switch then keep goingdown the line of troubleshooting this problem but hopefully that helps, and its a pain cause the car is so small that the space to get to the switch makes it fustrating, any more problems let me know i'll keep an eye on this post for a while ok
Good luck!
