bigtuboluvin »
https://forums.nicoclub.com/bigtuboluvin-u25190.html
Thu Dec 15, 2005 11:33 am
Wassup everybody, i have a 96 I30 and the brake lights are giving me issues. About four to six months ago i uninstalled the remote starter that i had installed a while ago. Ever since then i added Indiglo Gauges. After the gauges i notices my brake lights acting up. Recently, my interior lights have started acting up along with the exterior brake lights. When i brake the indiglo gauges turn on very dim, and the stereo and climate control displays go out as in blank. First, only one brake light wouldn't turn on, dismissed this being a problem early on because i still had three others. Then another one went out, all had good bulbs becasue i replaced them all. Then a third and final one went out and now the three that went out don't work properly at all. Although they do light, the three light up very dim when the parking lights aren't on, but when the parking lights are on they don't light unless you press the brakes. Almost as if they aren't getting enough voltage. I tried to clean the sockets but it doesn't work. Although i did find that when i wiggled the wire farther and farther away from the socket, the tail lights would miraculously work normally for a few hours, but then i discovered that everytime i brake, the front foglights come on and the gauges light up very dim, and the Stereo display and Climate control displays go out. Somebody please help me out.
