Any help would greatly help. My car is a 90 S13 if I forgot to mention. Please help because I do not want to get a bs ticket from are lovely police pigs.
Yes I checked over the wiring to the switches and it looked ok. All of the sheathing was still around the wires. Ill check under the fuse block to see if I see anything out of the ordinary around there. Thank you for the tip.MaximA32 wrote:Have you checked the wiring between the stop lamp switch and the fuse?
I tried this method as well. I had all of the assemblies unplugged to the brake lights and still blew. Thank you for the advice though.Q451990 wrote:Try unplugging each brake lamp socket assembly one at a time to see if you can isolate one of them as shorted. I assume the S13 has dual filament bulbs like the Q45. Sometimes the tips will melt and short out... It's also common to see corrosion between the tips in the socket - causing this kind of short.
Heath
Nope there is no kind of warning light on the dash. Just only for the fluid level. I did have aftermarket fog lights but those were ran off a completely different circuit and had its own fuse. I uninstalled them thinking that was the problem but no luck.Q451990 wrote:Does the S13 have any kind of brake lamp out warning on the dash? If so, you might check the sensor for that... we see those fail from time to time on the Q, but they usually just fail open vs. causing a dead short. I'm assuming you don't have any aftermarket wiring like trailer lights, etc... If you did I would certainly check those first.
Heath
