Debonair »
https://forums.nicoclub.com/debonair-u241370.html
Sun Jul 02, 2017 12:53 am
Replaced my front brake pads and the brake light stopped coming on during acceleration. So here is my theory. I think that the brake system and/or ABS pump pull some fluid down when the car is driving. Even with my old, worn down pads the resivour showed full when I would check it but the light would come on under acceleration. Now that my pads are new there is not enough room in the system to pull the fluid down low enough to set the light on acceleration. I did not add any fluid when I changed the pads either.
So the theoretical fix would be to add fluid as the pads wear down even though the resivour shows full. And then once the pads are replaced some fluid would have to be removed.
Thinking about it now, I haven't checked if my fluid is above full with the new pads, only checked that there was enough when I replaced I changed the pads. I'll have a look tomorrow.
