Two Fowty »
https://forums.nicoclub.com/two-fowty-u120229.html
Tue Feb 10, 2009 3:35 pm
Title says it pretty much. The light is pretty much always on when the car is on. It can go off in 2nd gear and up but then the light constantly makes a buzzing noise. It will come back on during a shift and then go back off after I'm going again. It will also turn back on (after being off) when I push in the clutch to brake and slow down, or just coast for that matter.
Ive noticed that when it is on, and I pull the e-brake it gets brighter, and then when I release the e-brake it will dim a bit, but still remain pretty bright. It is just a slight dim, you can barely tell unless you really look.
I don't think my brakes are dragging. They were after a 3 mile drive with the e-brake engaged.. fail i know. I fixed the dragging though I think, so I don't think they are dragging.
It isn't indicating worn pads or anything because I just went through the whole brake setup and replaced everything, so it's all new.
Any ideas on what it could be and how to fix it?
Flaming is fine, I just really want an answer on how to rid my car of this small issue.
