I am interested in installing a brake light flasher on my Rogue. I will be using the same flashing unit that I have installed on 2 motorcycles and am familar with basic wiring. My big question with the Rogue is where to wire it in. I have a trailer that I tow every now and then and would like the flasher set up to flash all lights (which would include the trailer) and not just the center brake light. Does anyone have enough experience with the wiring on a 2019 Rogue to know where this can be spliced in? It would need to be in between the brake light switch (brake pedal) and the point at witch the wire splits to go the three seperate lights.
Thank you for any help available.
