Debonair »
https://forums.nicoclub.com/debonair-u241370.html
Fri Oct 16, 2015 6:14 am
I don't recall seeing any sensors for brake pad wear on my 11' M, but I don't have the "S" trim.
It could be an ABS wheel speed sensor issue or even an issue with the parking brake sensor. You might have to get a scanner and check for codes from the ABS system. A higher end scan tool will also allow you to record the ABS data while the car is being driven. Then once the issue occurs the data can be reviewed and scrutinized to find the cause of the issue.
This could even be an alternator issue since the car is always under load when it happens, but this is less likely since (presumably) no other warning lights are coming on at the same time.
