Brake Light Coming On...
All things Altima Coupe.
xshinnyshinx
Car: 2011 Nissan Altima Coupe
When I'm driving and my RPM goes past 3k or so from pushing on the gas a little hard, my brake light comes on. Is this suppose to happen? It goes away when the RPM goes down. Sorry for the quality, iPhone camera.
T00Ezy
Car: 2012 Nissan Altima Coupe 2.5
that is abnormal. i get to like 5k rpm when i go on the highway never seen that happen. might want to get that checked out!
xshinnyshinx
I'll get it checked when I get my brakes changed. I don't feel any difference when the lights on, like it doesn't slow down my car or anything. Oh and my airbag lights are flashing too, and the stealership wants to charge me $50 just to look at it.
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
Usually that's the effect of the brake fluid being low. Get the brake fluid checked out, I can't help you on the airbag issue tho
Marisha
Car: 2008 Altima Coupe 2.5S
I had that problem too, ended up getting my master break cylinder replace under the recall. Not sure if your year is covered under it. Break fluid shouldn't just evaporate. Check your breaks first and make sure they are still good.
el_blacky06
it dont evaporate but he also mentioned hes gonna get his brakes checked out so im assuming he may need new brakes. that should cause the drop of the brake fluid
xshinnyshinx
I got an appointment set for next Tuesday, thanks for the help guys.
DJ_B_Easy
Car: 2017 GMC Sierra All Terrain X
Info here if you need it for the mfg replacement.
master-cylinder-recall-t557384.html?hilit=master cylinder
RiedelRidesVolkl
Car: 08 Nissan Altima Coupe s 2.5
shinnyshin, when you get the results from your appointment will you post results? i have actually just came across this problem as well and am very interested in what the problem is/ how to fix it.
RicerX
Car: '20 Titan Pro4X
In for results. Shout if you need something dude!
el_blacky06
that reminds me, even tho i replaced the master cyliner myself back in 2008 can i still get my money back thru nissan?
SanoSuKe
xshinnyshinx wrote:I'll get it checked when I get my brakes changed. I don't feel any difference when the lights on, like it doesn't slow down my car or anything. Oh and my airbag lights are flashing too, and the stealership wants to charge me $50 just to look at it.
To reset the airbag light.
1) Push the ignition from OFF to ON
the air bag warning light will appear for about 7 seconds and turns off.
2) Push ignition switch OFF immediately.
after ignition switch is turned OFF, wait for about 6 seconds.
after you REPEAT THE PROCEDURE 3 TIMES, push the ignition switch ON, this time the ABS warning light has been reset.
step on the brake and push the button to start the car. Turn the ignition off and start the car.
This method was used in the 2008-2009 models but I just used it on my 2012 and it works just fine. Let me know if you need any help.
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
Good for you for reposting this because I was too lazy. I use this all the time and it works great. Once in a while I have to do it twice.
xshinnyshinx
RiedelRidesVolkl wrote:shinnyshin, when you get the results from your appointment will you post results? i have actually just came across this problem as well and am very interested in what the problem is/ how to fix it.
Sure I'll post the results next week. Thanks for the airbag instructions!
DJ_B_Easy
el_blacky06 wrote:that reminds me, even tho i replaced the master cyliner myself back in 2008 can i still get my money back thru nissan?
Doubtful, might be worth a shot though. It was an $800 fix if I remember correctly. They took a very strange stance on the issue.
shift_craNk
Car: 08' Altima Coupe 3.5SE
this reminds me when my light kept coming on about 2 years ago... the guy said it was my brake pads and i needed knew ones... which made sense since they were going bad anyways, but ive been having this problem again for the past several month, and my brakes are still good for another year or more. so i will be calling nissan this weekends... i will update NICO about what happens after...
DAAN.
my master break cylinder was triggering that fault
in Canada there was a master break cylinder recall last year
xshinnyshinx
shift_craNk wrote:this reminds me when my light kept coming on about 2 years ago... the guy said it was my brake pads and i needed knew ones... which made sense since they were going bad anyways, but ive been having this problem again for the past several month, and my brakes are still good for another year or more. so i will be calling nissan this weekends... i will update NICO about what happens after...
Yes, let us know what happens. If I have to pay for this out of my pocket, I'm going to be really disappointed at Nissan. I'm pretty sure the warranty should cover it....
DJ_B_Easy
If you are within warranty mileage it will be covered. If you are not within warranty mileage, bring up the action notice.
xshinnyshinx
Okay so I did the steps so that the airbag lights would stop flashing, worked perfectly. Thanks again SanoSuKe. Now the BRAKE light doesn't come on anymore when I floor it. Still going to the Nissan dealership Tuesday to get my brakes replaced.
Mr.HacKeR
Car: 09 Altima Coupe 3.5
I think I read this before here on Nico..
Yup, here's the thread:
brake-light-keeps-popping-up-t432914.html
