Brake light coming on
All things Altima Coupe.
lindas08
Car: 2008 Altima Coupe 2.5
2 or 3 times a week, the brake light comes on and stays on for about 15 seconds then goes out. I checked to make sure the parking brake was off, and the brakes seem fine. Any ideas before I bring it to the dealer?
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
check yr brake fluid level.
lindas08
I'll check that. Thanks
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
I am having the same problem. Mine stays on way longer.
I think there is some sort of cable loose on the hand brake.
I was going to get this fixed at the dealership about a month ago, but i canceled and i am to lazy to make another appointment
Input22
Car: Altima Coupe 3.5
I had the same problem but I was low on brake fluid.
Mr.Coupe
Car: 08 Altima Coupe 3.5 BOOSTED
Input22 wrote:I had the same problem but I was low on brake fluid.
Same here. When I was on my way to work in the mornings it would come ON then turn OFF only when I turned the car off then back on at a red light, but it would turn back ON. I checked my brake fluid level and added some. It never happend again.
I would say check your Fluid Level first. It might be a simple fix. Good luck dude.
Ricky C.
Modified by Mr.Coupe at 11:22 PM 12/1/2008
Viperjunkie
Car: 2008 Altima Coupe 3.5SE
Mine came on and all my dealer did was tighten up my ebrake and i was good to go. never had a problem since
Hussain
Car: 08 Altima Coupe 3.5se CVT
same here
