Brake Light and Battery Light stuck on.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
its either OEM or KYB SR specials which you have to import from Japan.
oldmako
Car: '99 Infiniti Q45 190K Black&Tan
'96 Chevy Silverado 5.0 245K
'89 23' Irvette CC F351
memoryfab for the KYBs or someone else?
My old link for KYBs has croaked.
Thanks.
elwesso
2007 BMW M Coupe
i would actually go with Van from onetongarage.. he was a long time member here on the forum.
shadow98
Car: 1998 Q45
how do I get a hold of any of these people. Which KYB's specifically should I get?
rels95q45
Car: 1995 Infiniti Q45
This is the first post and I want to thank everyone for the awesome input I was able to replace my alternator yesterday and I was able to do it in about 3.5 hours (it was my first time).
Thanks again!!!
Now that it's done I was wondering if I could post two questions i have:
1) are there any instructions on how to replace my trip odometer bulbs on my 95 Q45? I don't want to wreck anything on my dash.
2) When I release my e-brake the brake indicator light stays lit even though the e-brake is completely released. I checked the button on the sensor and it moves smoothly but not sure if the entire sensor needs to be replaced. Any thoughts?
Thanks
soflokid
Car: 1999 Infiniti Q45
I have a similar problem. on my 99 Q, the brake lights are stuck on (the high brake light also). i noticed also when i engage the cruise control, it flashes and never engages. i am assuming this is because it thinks the brakes are being applied. any ideas?
msscomm
Car: 96 Q45t / 01 X5
soflokid wrote:I have a similar problem. on my 99 Q, the brake lights are stuck on (the high brake light also). i noticed also when i engage the cruise control, it flashes and never engages. i am assuming this is because it thinks the brakes are being applied. any ideas?
For that specific dual issue of Rear Brake Lights staying on and inability to get Cruise Control engaged - post6003090.html?hilit=brake%20switch - check if the switches work manually, but if both switches are sitting in the holes and NOT hitting the rubber baby buggy bumpers - you're about 100% sure (and finding the pieces is another give-away)
