Ok, so after unhooking all of the alternator's wires,
nuts510 wrote:I would start out by disconnecting the alternator from the circuit, this means unhook all the wires going to an alternator. if the fuses quit blowing replace alternator and try again
the fuse still burnt out as soon as I turned the key.
I followed the wiring diagram for my car and the circuit that the fuse is on is the solenoids... I disconnected each solenoid: SCV, AIV, EGR, PR, and AAC. Tried the fuse again blown.... This is starting to piss me off! The only thing left in the circuit is the Bulb Check relay,the wires themselves and as remote possibility the computer. I can't get to the bulb check relay today as its located in THE WORST SPOT EVER! Behind the main harness up under the dashboard. I'm going to work....
Please help with any suggestions or ideas... I'm about to call it quits!
