Cyberkreig »
https://forums.nicoclub.com/cyberkreig-u962.html
Tue May 04, 2004 12:45 am
Brakes are nothing to mess around with, if you dont feel confident you can fix it then get it fixed.
I would have you first check the brake fluid level, and look for leaks in the system. Other than that I would guess that i might be the brake master cyl. Those constantly go out.
If you are stopped on a hill. does it require more and more petal travel to keep the car stopped? I.e. does the petal sink slowly to the floor? If so you need a Brake Master
