C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Thu Dec 14, 2006 9:45 am
Anytime you pump the brakes, the pedal will become stiffer and engagement will be higher. Master cylinders work by revealing an orafice to the reservior when the pedal is released. But if you release the pedal and then push it in again quickly, the negative pressure in the lines when releasing the pedal will pull a small amount of fluid into the cylinder from the reservior. When you quickly depress the pedal again, you won't give the system a chance to equalize the pressure and you'll force more fluid into the cylinder than before, which raises the engagement point. This is why you're instructed to pump the pedal if you ever lose pedal pressure. You can actually get some braking if you force some additional fluid or air into the lines if you should ever have too much air in the lines or perhaps a leak.
Try pressing and releasing the brake, then wait 10 seconds or so and do it again. It should have the same pedal engagement height.
