brake kit on e-bay please advise
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
saw on e-bay apparently these rotors fit Q lug pattern but larger than z rotor thus adaptor for calipers to fit ??http://cgi.ebay.com/ebaymotors...S%3A1
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Check the threads by AZHitman. Think they were more trouble than they were worth to adapt.
Modified by maxnix at 3:31 PM 8/3/2006
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
its not realyl any trouble, however its just for looks.... Braking distance doesnt really get any better as the pad swept area is roughly the same.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
I thought the caliper brackets had to be fabricated or something?
I forgot because I don't want to go that way.
Rex
Car: None
maxnix wrote:I thought the caliper brackets had to be fabricated or something?
The kit in the link james posted "appears" to have the brakets with it.
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
That is a great deal, even if you just put the calipers on your car.
I hope you get it.
It would help on the race track, where the rotor heat affects braking. About turn 11 at Barbers on lap 6, you will wish you had bigger brakes, no matter what you are driving.
Nothing like a 40 MPH turn after a 1/4 mile straigh, where you cang get up to about 130 MPH! Those counters are there for a reason 5, 4, Shift, 3, Shift, 2, BRAKE!!!!!!!, 1, Shift, Pray, Turn, Gas!!!!!
