Quote »What pads should I get? Will I need any other parts or tools?[/quote]See
NICO Forums > Online Mechanic > Infiniti Online Mechanic > 1990 Q45 Brake Pad R&R (BRAKE PADS WORN)
Assuming the parking brake remains untouched, the parts list includes:
- Infiniti Q45 Front Brake Pads (Part #41060-64U91) $64.49
- Sensor & wire is included for the right inboard front pad
- Infiniti Q45 Rear Brake Pads (Part #41060-66U85) $56.24
- Sensor & wire is included for the right rear inboard pad
- Front Hardware Kit (Part #41080-60U27) $45.70
- Rear Hardware Kit (Part 44080-60U25) $45.70
- Packet of high temperature brake grease is included with each axle set
- 3-day ground shipping (via Airborne Express) $10.46
- Total: $222.59
Note the suggested front hardware kit contains:
- #41083-60U04 SPR-RET, PAD (4 pcs)
- #41083-60U05 SPR-RET, PAD (4 pcs)
- #41084-60U00 SHIM (4 pcs)
- #41085-60U00 SHIM-COVER, INNER (2 pcs)
- #41085-60U01 SHIM-COVER, OUTER (2 pcs)
- #41003-03P25 GREASE (2.5g)
While the suggested rear hardware kit contains:
- #44083-44F00 CLIP-PAD (4 pcs)
- #44084-60U00 SHIM-OUTER (2 pcs)
- #44084-60U01 SHIM-INNER (2 pcs)
- #44085-60U00 COVER-SHIM (2 pcs)
- #44086-60U00 SHIM-INSULATOR (2 pcs)
The suggested tool list includes:
- 12 mm box or open-end wrench (plus 12mm socket for torque wrench)
- 14 mm box or open-end wrench (plus 14mm socket for torque wrench)
- 17 mm box or open-end wrench (plus 17mm socket for torque wrench)
- 2 inch micrometer (for front rotor thickness test)
- 1 inch micrometer (for rear rotor thickness test)
- 0.0001 inch dial-gauge with vise-grip flex-arm jig (runout test)
- 12 inch chisel-end pry bar (for restraining front rotor)
- 12 inch claw-end pry bar (for turning rear rotor)
- torque wrench (up to 60 pound feet)
- disc brake spreader (preferably with two bolts; otherwise add a thin steel force-distribution plate)
- two cotton swabs (denuded of cotton)
- a dime & a felt-tip pen (to check scoring depth)
- 2-ton floor jack, at least 4 wheel chocks, & 2 adjustable jack stands
- BBS hubcap remover (BBS wheels only)
- Rubber mallet (for obstinate parts)
- Two 8mm x 1.25 mm/inch x 3 inch bolts (for removing the rotor from the hub)
- 13/16 inch lug nut wrench and socket (for torque wrench)
- two 12mm x 1.25mm/mm flat-ended (not tapered) steel nuts (optional)
- shop towel (to clean up brake fluid spills)
- TP wrapper (not the TP itself) to buff caliper pins smooth
- 2 large 12 inch tie wraps or steel wire (to hang calipers up)
- chalk (for marking tires, wheels, pads)
- Vacuum style pump (for one-person bleeding & lowering master cylinder fluid level)
- DOT 3 Brake fluid (for bleeding)
See the complete step-by-step in the aforementioned NICO thread.
