Brake issues
mikedamageinc
Car: 2012 Infiniti M37x Touring
1999 Chevy Camaro SS
1997 Toyota Land Cruiser
2008 GMC Yukon Denali
Does anyone know the fitting size on the brake master cylinder lines?
and
Has anyone adjusted the pushrod in the brake booster? (or if is even possible?)
Backstory: on a long highway trip i noticed the brake pedal got soft but would pump up and only after a long stint on the gas, and absolutely no issues driving around town. I replaced the master cylinder with a parts store type and lots of bleeding the pedal goes down too much before engaging the brakes. It doesnt feel like air, i think the aftermarket master has a different size plunger (it only takes thousandths of an inch to be way different pedal feel. I want to adjust the pushrod in the brake booster (usually an acorn nut on the end of a threaded rod) and to get the master out will make a huge mess of brake fluid again and would be nice to have some plugs and caps ready
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
See BR-7 and BR-8:
https://www.nicoclub.com/service-manual ... 2%2FBR.pdf
There's a locknut on the pushrod yoke for adjusting pedal height and a spec for distance to the floor, but depending on the design of the pedal brackets, some of the locknuts are a complete PITA to get a wrench on. Haven't done that particular adjustment on an M (I'm a Nissan tech), so you'll have to see what's in there.
mikedamageinc
In case anyone is wondering it's M12x1.0
I ordered a fitting checker in Amazon, one for metric and one for standard. Between these and the bolt thread sizer I also ordered on Amazon, going to save a lot of time taking bolts to home Depot!
VStar650CL
Technical Expert
Very cool! :dblthumb:
mikedamageinc
Following up on this issue, I think the system has some sort of self adjusting as the brake pedal now feels normal. Not sure how long it actually took since it my wife's daily and I drive it once a week or so. Bouncing between multiple vehicles I never really thought about it until recently and thought maybe I just got used to it but it actually has firmed up like it should be.
