KickinPups2 »
https://forums.nicoclub.com/kickinpups2-u204596.html
Wed Jun 13, 2012 9:29 pm
Okay so as the subject says I'm having some issue..I just changed out my rear pads which I have done numerous times on my old G...Now the the G-07 and M-07 have the same braking system. Yet for some reason after changing my pads I had really squishy brakes(Usually means air in the system) So I bleed my rear brakes both sides..Even had my mechanic put it on the lift and bleed all 4 and check for leaks....We didn't see any leaks and now I'm at the point where I think it's the master cylinder...I recently ordered a new one and plan on putting it in myself. My question is has anyone ever done it? had issues doing it? Also there is ABS on the car won't that cause issue when changing out the master cylinder? I was told I may have to bleed the master abs system since Im changing out the master cylinder. I have never done this before and may just have my Mech do it if it is to tough...
