HijackTheLeft »
https://forums.nicoclub.com/hijacktheleft-u27186.html
Mon Oct 01, 2007 8:12 am
I’ve had a couple brake issues lately, and I’m not sure if they’re connected or not. First, a few weeks ago, my brake pedal felt a little loose, like I was having to push down farther than normal to get the brakes to engage. It was barely noticeable, and after I checked my brake fluid, and got back in the car, it was fine, so I attributed it to my imagination. It didn’t do it again for a while, but on my way home from work last week, I had to press my brake pedal all the way to the floorboard before the brakes would work. It was kind of gradual, but it got to that point pretty quickly after leaving work. The next morning it was fine. It’s been fine since. Secondly, my Brake light on my dash has been coming on for no reason. I’ve finally figured it out when it will do it. After it sits for a while, for the first couple minutes after starting my car, if I take a right turn, the light will come on, and then if I take a left turn, it will go out. The longer the car sits, the longer it will take to stop doing that. And this is a gradual thing to. When I first start the car, it’s pretty sensitive and any change in lateral momentum will affect the light. As I drive it a while, it gets less and less sensitive until finally, everything seems fine.I just had my car inspected last month, and specifically asked the mechanic to check the brakes because they had been squealing. It was barely audible, but I figured it was worth checking. He said the brakes were in great condition. Does anybody have any thoughts on this issue?
