That was the point - stock 16.5-17.5 pounds in a 28 mm thick x 11" rotor obviously warp. Currently 2,500-3,000 pound performance cars use the same diameter x thickness brake systems as the old Q.
On heavy Lux cars 30-32 mm seems to be the common thickness now, but since the ratio [metal, air space,metal] is 1:1:1 or less [why don't the thicker rotors weigh significantly more].
You either increase the rotor mass [weight] or increase the air space between the parallel outside planes [while increasing their thickness 1-1.5mm [oem Q is at 9mm per plane and 10 mm of air space].
http://www.statixbrakes.com/ap_competition2.asp
For 350Z/G35:Front Type Vented Disc, 2 caliper pistons Rotor size diameter and thickness (in.) 11.65" x .95" [24.5mm?]Rear Type Vented Disc, single caliper piston Rotor size diameter and thickness (in.) 11.50" x .63"
Brembo (Standard on Track) Front Type Vented Disc, 4 caliper pistons Rotor size diameter and thickness (in.) 12.76" x 1.18" [30mm]Rear Type Vented Disc, 2 caliper pistons Rotor size diameter and thickness (in.) 12.68" x .87" [22mm]
Even the Z Brembo fronts are only 30mm but then again this is a 3500 pound car.
http://www.zeckhausen.com/E39_...l.htmh ... pgrade.htm
