brake indicator light in the panel on and off
jun03045
Car: Nissan xterra 2002 4wd
when you hit the brake pedal the red indicator in the panel wll turn onand stay on until you hit the brake pedal again or hit a bump then itwill go off...what is the problem
2002 Nissan xterra
driftingmy240sx
Car: 1996 Nissan 240sx rb25det
more than likely you are low on brake flid in the resivior. i would also have the brakes checked as they may be low and causing the problem with low brake fluid
